Michael Heit Excalibur Build
Date:  12-2-2005
Number of Hours:  2.50
Manual Reference:  AC 43.13
Brief Description:  Fabricate access door trim brackets
Photo 1: Side view from the left side of the AC of the new access door area. This will make refuling from outside the cockpit easier, and access for inspections much easier. There will also be an access door on the right side as well.Phot 2: The rear deck area will have a built in tray area for tools, oil, spare plugs, etc. and will be sealed on top with a canvas cover secured with velcro. The heater 4" ducting tube will traverse through this area towards the cockpit. My electrical Keywest regulator, the starter solenoid, and the positive / negative bus connectors will all be mounted here too, it will all have a clear lexan cover over it to seal it from the elements, and safety.
Side view of access doors
Rear Deck Storage Space
John welding in shop
