Michael Heit Excalibur Build
Date:  9-19-2008
Number of Hours:  0.50
Manual Reference:  Poly Fiber Manual
Brief Description:  Calibration of Irons.
Photo one is the first temp setting for the big iron, 225 degrees F.
Photo two is the bottom side of the hobby iron and applying the heat sink paste. Just a small dab will do the trick. This silicon based paste is available at Radio Shack for a few dollars, and transfers the heat directly to the thermometer. The thermometer shown can be purchased from Poly Fiber for about $3.50 ... it is well worth the price since it is precalibrated to the tempratures you need to set.
Photo three is the first calibration setting of the iron, the mark on the face of the iron is where the 225 degree setting is for this iron.
225 degrees F on big iron
Heat sink paste on small iron face
225 degrees calibrated on small iron
