Photo 1 is the stand off for the elecrical harness from the front to the rear of the fuselage. This is one of two main harnesses coming from the front to the rear of the aircraft.Photo 2 is the main battery cable stand off. Photo 3 is the second main harness coming from the front to the rear, the stand off has been installed, and a temporary pull tie is atached to this stand off until I can install a second harness cable coming down from the engine to the electrical buss blocks on the rear deck plate.
Harness cable standoff
Main battery cable stand off
Stand off for harness coming down from the engine.
