Michael Heit Excalibur Build
Date:  12-26-2005
Number of Hours:  8.00
Manual Reference:  QCBM / AC43.13 /
Brief Description:  Install CHT / EGT Connectors
Photo 1 shows the link cable I made to connect the CHT sender contacts to the electrical buss line. The ends on the Inconel CHT lines are straight connector type, the electrical buss is the round screw down type. This link makes the match with out introducing any error in tempratures due to incompatible metals in the sensor line.Photo 2 shows the link line installed to the CHT sender cable.Photo 3 shows the shrink tubing at the connections to the engine cable harness.
Connector link cable
Link installed
Link installed
Shrink tubing applied
