It's December already and I haven't made any log entries for a week or more.Photo 1: I have removed the fabric from the rear sides, and installed aluminum angle material for access doors that I will fabricate and install later. I also added a solid sheet backing behind the rear seat for better sealing of the cockpit since I will be installing a heater system. This panel will be installed using PK screws since I will need to keep access open for changing the main tank.Photo 2: Here you can see the fuel pump mounted now in the rear area behind the back panel. The inline fuel filter is located on the outlet of the tank, and the inlet of hte electric pump. Photo 3: this is a closer look at the Fawcet Electric fuel pump.
