Brief Description: Updated Skyview software, did systems checks
Updated Skyview to version 14.2.1 including the applicable avionics software. Still have a weak headset audio. Both Pilot and Co-Pilot can transmit "loud and clear".
PAP G1-1: The stall warning is heard on the headset with the stall vane raised. Did calibration of the Autopilot servos and they tested OK. The Strobes and NAV lights work.
45A-10: Tried adjusting the potentiometers in the Control Module including Com 1 and Com 2 and, again, there was no noticeable change in the volume or distortion. I'll need help and/or do more research to fix this.
