Brief Description: Work on Dynon SV wiring upgrade
Still working on the Dynon SV-1000 wiring upgrade. Connected the pins on the WH-00026 Rev 1 kit to the WH-00026 "OPTIONS" backshell and connected the wires to the Pilot and Co-pilot headset harnesses. Connected the Wht/Blk wires from the headset harnesses to the WH-00026 "AUTOPILOT" backshell. Routed several wires (WH-P325, WH-P323, WH-F319, WF-F320, WH-F321 and WH-322) to the back of the fuselage. Connected the WH-00008 Skyview OAT Connection Harness to the OAT Wiring Harness using butt splices. Crimped a spade connector to the WH-P350 Power Outlet Wire and connected to the power outlet (replaced the WH-B148 which was removed from the tunnel).
