Installed backshell assemblies on the Optional and Tunnel Harnesses. Routed the Optional Harrness wires to the left and right side of the fuselage per the plans. Made the WH-B184 Nav/Strobe Power Wire. Crimped floating pins to the wires in the left and right sides of the fuselage per the plans. Crimped a spade connector to the WH-L72 and the Nav/Strobe Power Wire. Connected the noise filter to the wires in the left side and inserted the pins into the back of the ES-00077 Floating 8 Pos Connector Female.
Replaced the reset switch in my air compressor and it works.
