Brief Description: Redrilled holes in nose leg, fixed fuel leak
Re-drilled the holes at the side of the nose gear assembly to #30 and tapped to 8-32.
Noticed drops of fuel on the hangar floor. The fuel was dripping from the gascolator aroung the 90 degree fitting. Removed the fitting and replaced it with a new one (AN822-6D). Reconnected the fuel lines. This seem to have corrected the fuel leak.
