Removed the nose wheel fairing aft and match-drilled #19 holes in the U-00006A-1 Wheel Fairing Brackets. Attached the U-00006D-1 Doubler Plates to the brackets. Had to grind the front outboard part of the right doubler plate to make it fit. Match-drilled #40 holes into the wheel fairing brackets. Dimpled the wheel fairing brackets and countersunk the doubler plates. Riveted the doubler plates to the brackets. I could not dimple 3 holes in the brackets because they are too close to the nutplates. Used AN470AD rivets on these holes and there was no interference with the nose fork.
