Removed the Top and Bottom Cowls to make sure there are no leaks. Everything looked OK.
45A-02: Covered the holes for the regulator in the F-1201B Firewall Shelf with AN4-4A bolts and washers.
Put air in the tires to replace what I released for the weight and balance.
PAP G8-1, Dynon Skyview Pilot User Guide: Did fuel system calibration per the SV guide. Everything went OK . It was just time consuming adding 1 gallon at a time and adjusting the EFIS.
