Brief Description: Reviewed Pre-start procedure, Canopy Fairing work
POH-ii (7-4): Reviewed the pre-start procedure to see the EMS display. Turned the Fuel Selector and Master Switch ON. The fuel pressure went up to 1.8 PSA only (low) but I only have about 2 galllons of fuel in the tank.
34-15: Spent most of the workday sanding the Canopy Fairing and there is still a lot of sanding to do.
Checked for fuel leaks and none found. Removed the blue vinyl film from underneath the wings.
