Drilled #40 holes into the aft plastic sleeve of the rudder cables and safety-wired them to the fork ends. I'm not able to continue further with Section 32, Flight Controls, because the Tailcone is not yet attached to the Fuselage. I'm waiting to finish all the mods, upgrades and Service Bulletins in the Tailcone and rear of the fuselage before I connect the two assemblies together.
Reviewed the Skyview conversion harness wiring especially the Optional and AutoPilot harnesses in preparation to wiring the SV AP Knob Panels.
Found somebody to help me turn the wings over so I can do SB-14-11-03, RV-12 Wing Skin/Spar Flange Rivet Wear. Marked the wing skins where the W-1201A Doublers will be riveted.
