Brief Description: More work on cowling and started work on FWF
38-06: Sanded the edges of the Top and Bottom Cowls some more but still have some overlap. Have decided to finish this later after the engine is hung to make sure I don't remove too much material from the cowls.
45A-06: Started work on the FWF kit. Made 2 F-1201D Battery Spacers. Cut the F-1257B Battery Anti-Chafe Strips into 4 pieces. Bolted the 100434-000 Manifold Pressure Sensor and the ES 24115 Mater Relay to the Fuselage.
