I was not able to work on the plane for almost a month because of various reasons, one of which was I did not have a 10-24 tap and had to order it from Avery Tools. Today I tapped the W-1217C Fuselage Pin Stoppers and inserted the magnets in the center holes and then filled the holes with epoxy. Installed the Pin Stoppers in the W-1217 Fuselage Pins and installed the screws with plastic tubes and bushings into the Pin Stoppers. Applied Loctite 242 per the plans.
