Primed the forward edge of the upper Tailcone and the upper edge of the Fuselage side skins which will be overlapped by the F-1277 Fwd Turtle Deck Skins. The paint on the Roll Bar is peeling off and I decided to repaint it. I spent a lot of time removing and sanding the old paint off. Cleaned the surface with acetone and sprayed primer on the Roll Bar. Will plan on applying a clear coat over the primer on the Roll Bar instead of the hammered silver finish which has not been durable.
