Brief Description: Riveted the other Seatback Assembly
Riveted the other Seatback Assembly, attached the Seatback Brace and safety-wired the hinge pin. Also fabricated the 4 hinge pins that will attach the Seatbacks to the Fuselage. However, will not install the Seatbacks at this time to make it easier to roll the fuselage to its side if I need to when work on the next sections. Torqued the bolts in the lower corners of the Seatback Assemblies and applied torque seal. I'm not sure if this is required but it will do no harm. Separated the F-1207E Shoulder Strap Lugs, chamfered the edges per plans, radiused the corners and deburred the other edges.
