Brief Description: More fuselage parts preparation
Couldn't do any priming today. It's too cold. Prepped several parts to keep busy. Final-drilled #12 and1/4 holes in the WD-1210 Control Column. This was hard to do on the holes closest to the column because there is no space for the cordless drill. I had to use a right angle attachment to the electric drill and a right angle manual driver. Dimpled the holes in the F-1212 Step Ribs and F-1202F Bulkhead. Separated the F-1275 Fuselage Corner Skins, F-1204Z Bottom Stiffeners, F-1268 Doublers, F-1236 Step Attach Angles and F-1251 Nutplate Brackets, and deburred the pieces. Trimmed 2 of the F-1236 Attach Angles per plans.
