Brief Description: Assembled the Control Column Mounts
Riveted the Control Column Mount Spacer (F-1233A) and Control Column Mount Brackets (F-1233B) together to make 2 Control Column Mount Assemblies. Riveted the F-1203B Bracket Flanges to the F-1203A Bulkhead. Riveted the F-1203C Stub Spar Receptacles and F-1203D Stub Spar Receptacle Supports to the Bulkhead (2 rivets each side). Partly riveted (LP4-3 rivets only) the F-1203E Bulkhead Doublers to the Bulkhead. Will finish riveting Doublers with solid rivets tomorrow.
