Prepared parts that will be needed for later steps. This is so I can prime several parts at a time. Separated the F-1203B Bulkhead Flanges and F-1203D Stub Spar Receptacle Supports and deburred them. Also deburred the F-1233B Control Column Mount Brackets and F-1233A Control Column Mount Spacers. I still need to Scotch-brite them before priming. Located the bushings I'll use in the next steps.
