Brief Description: Completed R Flaperon and worked on Extensions
Riveted theA-1201A-R Inbd Nose Skin and A-1201B-R Mid Nose Skin to the Flaperon skeleton. Inserted Rod end bearings into each Pivot Bracket after applying Loctite to the threads. The Right Flaperon is now complete!
Applied fuel tank sealant to the lower flange of both W-1222 Left & Right Extensions and then riveted it to the wing tip. Followed Steps 1 thru 7 of Section 40-09. Mixing the sealant was a pain. Just need to install the Nav/Strobe lights and the Wings will be complete.
