Brief Description: Fabricated another Right Actuation Bracket
As mentioned in a previous entry, the hole in the A-1207-R Actuation Bracket did not perfectly line up with the hole in the A-1208 Bracket Assembly. Therefore, I decided to make a new Actuation Bracket and got an an aluminum angle from Wicks Aircraft Supply. I cut the piece to the measurements in the plans and did a lot of deburring. I still need to drill the 3/16 hole and some deburring. Hopefully, this piece will fit better.
