Brief Description: Work on Actuation and Pivot Brackets
Match-drilled the A-120 Pivot Brackets and A-1207-R Actuation Bracket and deburred the holes. Completed deburring the A-1203 spar. The hole in the Actuation Bracket does is not perfectly aligned with the hole in the Inbd Nose Rib Bracket Assembly. I may have to fabricate another Actuation Bracket.
