Deburred the A-1202-L Inbd Flaperon Skin and the A-1207-L Actuation Bracket. Primed them and the A-1202B Outbd Flaperon Skin. Riveted the 3 Outbd row of holes in the Actuation Bracket with the spar using solid rivets. The filing of the inner angle allowed the manufactured heads of the rivets to sit flush on the "web." Riveted the A-909/A-1204-L and R Outbd Nose Ribs/Counterbalance Assembly to the spar. Riveted the remaining A-1205 Main Ribs, the Inbd Nose Rib and Bracket Assembly and the A-1210-R Inbd Nose Rib. Clecoed the Inbd and Outbd Flaperon Skins to the main ribs and spar. Fit is excellent and no adjustments were needed.
