Brief Description: Work on Right Wing Tip Extension
Drilled a #19 hole for the ground wire near theWing Tip Access Opening. I forgot to do this yesterday. Trimmed the W-1222-R Extension closer to the scribe line using a rotary tool with a metal cutter. This worked really well and less sanding of the edges was needed. I wish I had used the tool on the Left Wing Extension. Drilled out 3 rivets from the Wing Tip Close-Out. I was not thinking about these holes for the Extension when I riveted the Close-Out yesterday.
