Brief Description: Prepared wiring for Landing Light
Made a WH-B215 Landing Light Ground Wire and installed a female Molex pin on one end and a Ring Terminal at the other end. Attached it to the W-1223B-R Landing Light Rib. Installed Molex pins to the ends of the WH-B213 Pulse Power and WH-B214 Landing Light Power Light. Attached the pins into a female Molex Connector Housing. Crimped female Molex pins to the end of the the LL-200 Landing Light Wires and installed into a Molex housing. Connected the two Molex Connector Housings and installed the Landing Light.
