Brief Description: Riveted Main Ribs and the Rear Spar Assembly
Received the "care package" from Van's with the LP4-4 rivets and was able to rivet the remaining Main Ribs to the Spar. Match-drilled #30 two holes in the most inboard Main Rib and deburred the holes. Clecoed and then riveted the Right Rear Spar Assembly to the Main Ribs.
