Brief Description: Prepared wiring for wing tip lights
Delayed doing the step in 40-07 that asks to put flox on the extension. I don't feel comfortable doing this yet and will wait for the weekend when I have more time. Prepared the WH-B211 Nav/Strobe Ground wires. Made the mistake of cutting 22G wire and it appeared too small for the Molex pins. The pins look weird and I haven't used them before. Spent some time on the Web looking for instructions on how to crimp them and also to figure out which is male and female. Finally installed the female Molex pins to the and ring terminals to the correct size wire (18G). Attached the ground wire to the Wing Tip Close-out. Not much accomplished in 2 hours because of lack of familiarity with this process.
