Brief Description: Priming, Lighting System Wiring and Riveting
Primed the left 3 bottom wing skins. Made 2 WH-B212 Nav/Strobe Power Wires, a WH-B213 Pulse Power Wire and WH-B214 Landing Light Power Wire per plans. Removed the Left Terminal Bracket and installed the Nav/Strobe Power Wire and routed through the snap bushings to the most outboard Nose Rib. Riveted most of the bottom of the Inbd Wing Skin. Had to stop riveting around 9 PM to be a good neighbor.
