Brief Description: Installation of the Terminal Brackets
I still had trouble getting the microswitch to activate when the stall warning vane was moved. I bent the arm a few times and after several tries was able to make the switch "click." Prepared tthe WH-B218 Terminal Wire and attached it to the Stall Warning SubAssembly. Installed a fishing line from the outboard to the inboard ribs per the plans. Prepared 2 WH-B216 Terminal Ground Wires and installed one to the Left Terminal Bracket. Finally, I attached the Bracket to the W-1208-R Inboard Rib. One end of the Ground Wire is not connected. I will do it later when I install the wiring for the lights.
