I don't have extra workbench space to start assembly of the right wing (per plans) with the left wing skeleton still on the workbench, so I decided to continue working on the left wing. Final-drilled the VA-195A Mount Plate and the VA-195B Keeper Plate. Countersunk 3 holes in the Mount Plate. Removed excess material from the Terminal Brackets (W-1205 L & R). Deburred the holes and edges and primed the parts. I then assembled the Stall Warning Subassembly. There were too many washers to put and it was hard to determine which was standard and "L" because they all appeared to have the same thickness. Match-drilled and final-drilled the 2 UHMW Blocks and deburred the holes.
Finished priming the rest of the W-1208-L Nose Ribs.
