The holes in the Right HS-1218A Aft Hinge that I had drilled before did not not line up well with the holes in the trailing edge of the Main Skin. I'm not sure why. I had positioned the template consistently during match drilling of the holes. So, I got another hinge from Aircraft Spruce and trimmed and match drilled it per instructions. The holes matched up better with this replacement hinge.
