Brief Description: Upper and lower spar caps. Priming issues.
Match drilled right upper and lower spar caps and then did sanding and deburring. Removed primer from upper and lower hinge assemblies and used another spray can primer from the hardware store. The new primer worked better. Got my son, Steven, to "help" with drilling.
