I'm still smelling gas every now and then. Upon opening the canopy I noticed a slight smell of fuel in the cockpit. Removed the carpet from the fuel tank and baggage floor. Put a videoscope behind and outboard of the fuel tank and did not see any leak. There were a couple of fuel stains on the the top of the tank around the fuel vent fitting and near the T-1204B Flange. Tightened the fitting approximately 1/4 turn. Repositioned the T-1212 Fuel Neck Collar and tightened the clamps.
Removed the F-1230 Tunnel cover and the baggage floor covers. There were no fuel leaks in the tunnel.
32-06: Adjusted the right Flaperon Pushrod Assembly by "tightening" the F-3514M bearing to make the droop of the right Flaperon within specs. After the adjustment the Flaperon trailing edge is 5/16 inch from the wing trailing edge.The PAP specifies between 1/4 to 1/2 inch.
Reinstalled the tunnel covers, upholstery and seats. Reconnected the Molex plugs of the AUX Music jack.
