My RV-12 Build Log
Date:  12-30-2018
Number of Hours:  5.00
Manual Reference:  SB18-02-02; 11, 32
Brief Description:  Stabilator Front Spar Service Bulletin
Attached the Stabilator Assembly to the Tailcone. Torqued the AN4 bolts to 95 in-lbs. Reconnected the aft stabilator cables to the stabilator horns. Connected the F-1287E Pushrod to the Anti-Servo Tab Assembly. Tightened the turnbuckles connecting the fwd and aft stabilator cables. Trimmed the upper and lower tailcone fairings to have enough clearance between the gussets and the fairings. Aside from checking the stabilator cable tension this SB is complete.
H-Stab connected to Tailcone
Clearance at top of H-Stab
Clearance bottom of H-Stab
