Brief Description: Upgrade to Silent Hektik Voltage Regulator
The electric fuel pump would not turn on with the Master Switch in the ON position. Tried repositioning and re-inserting the wires in the regulator housing without success. Since I had ordered and received the Silent Hektik regulator I decided to install it. This regulator installs on the front of the firewall. Repositioned the regulator wires from under the Panel Base to the engine compartment. Countersunk 1 screw hole in the FF-00123 Regulator Adapter Plate. Installed the regulator on the plate and the regulator assembly on the firewall.
