Brief Description: Installed right stabilator tip fairing
Riveted the outboard stabilator ribs on the right side. Match-drilled holes in the right HS-1225 Stabilator Tip Fairing and riveted it to the stabilator.
Drilled out the rivets in the left outboard stabilator tip and removed the HS-1205, HS-1207 and HS-1208 ribs.
