My RV-12 Build Log
Date:  11-10-2009
Number of Hours:  1.00
Manual Reference:  11-07
Brief Description:  Riveting of Pushrod Assembly
Reassembled the primed Pushrod Assembly and riveted the Clevis Plates to the Pushrod. Also riveted the Threaded Insert and installed the MM-3 Bearing. Threaded the Pitch Trim Servo to the Assembly to check for fit and removed it. I will permanently install it when I put together all the tail parts later, maybe in a hangar somewhere.
Riveted Pushrod Assembly
Bearing attached to Pushrod
Assembly looking aft
