Attached the V-Stab to the Tailcone and the Lower Hinge Assembly to the V-Stab. I did not fully tighten the bolts yet. Temporarily attached the Rudder to check fit. The travel is good with no catches or binding. I'm not sure at this point if I will permanently install the Rudder. Space is getting scarce in my garage/airplane factory and there are several more subkits to build.
