Brief Description: Replaced Tee connector to brake reservoir
I had noted some brake fluid on the floor (pilot side) and it seems to be coming from the Tee connector behind the brake fluid reservoir. Drained the brake fluid, removed the old fittings and installed the new FLF-00004 Push-To--Connect Tee to the VA-107 Brake Reservoir, and then re-connected the left and right brake lines. Purged the brake lines.
