Brief Description: Adjusted stall warning vane, Trim setup
Bent the stall warning vane upward. I had previously bent it downward to increase the gap between the buzzer and stall break. However, the instruction in the PAP was wrong. This was reported in the VAF forum but somehow the PAP has not been corrected yet.
Set the take-off trim in Skyview. I can now see a green line on the Trim Bar on the EFIS.
