Brief Description: Replaced Panel screws, installed fire extinguisher
Installed two K-0003 nutplates on the F-1230 Tunnel Cover that will be used to secure the fire extinguisher bracket. Attached the bracket to the Tunnel Cover with AN3-4A bolts and AN960-10L washers and installed the fire extinguisher.
Replace the screws on the right instrument panel with black brass screws.
