Brief Description: Tightened landing gear bolts, checked for leaks
Checked the landing gear bolts at the main wheels. A few bolts on the right side needed tightening to 100 in-lbs. All the bolts at the left main gear are still within specs. Remove the F-1230 Tunnel Cover to check for fuel line leak and there was none.
