My RV-12 Build Log
Date:  6-22-2016
Number of Hours:  1.00
Manual Reference:  31B, PAP
Brief Description:  Repaired a Trim wire, Check Comm radio
31B-04: Removed the pin in position 22 of the Tunnel harness connector. The pin was connected to the WHT/BLU wire from the P-30 Trim harness which I found disconnected 2 days ago. Crimped a Molex pin on the WHT/BLU wire and inserted in position 22. Tugged on each wire to ensure all are properly seated. Sprayed DeOxit Gold on the pins and joined the 2 Tunnel connectors. The AST moves up and down when the Trim switch is activated.
PAP G1-1: Checked the GTR 200 radio again and played with the settings. The sound when the Monitor switch is off is again weak at 100% volume. At times it is intermittent. When the radio is first turned ON the volume sounds "normal" momentarily but then gets weak again. I'll have to recheck the wires and settings again.
Tunnel harnesses re-joined
