My RV-12 Build Log
Date:  5-13-2016
Number of Hours:  1.50
Manual Reference:  42G, PAP, 34
Brief Description:  Worked on Comm and Canopy Fairing
42G-04, PAP G1, Garmin GTR 200 Install Manual: Went to the Config Mode of the GTR 200 to see if ICS is enabled and it was. Played with different settings and still couldn't get the audio volume to normal with the MON button off. Will work on this later. Checked the AP and it was on but I do not see the Knob Panel lights. It seems to want to go to Nose Up trim. I'll work on the settings later.
34-16: I did more sanding of the Canopy Fairing and applied epoxy microballoon mixture to the low areas, mostly in the aft corners. Applied UV Smooth Prime over most of the fairing except where the fresh microballoon mixture was applied.
Garmin GTR 200 setup
Fairing with UV Smooth Prime
