Brief Description: Installed EFIS, AP Knobs and ADSB
42C-05 (Rev 3): Installed the SV-D1000 Touch EFIS to the left Instrument Panel and connected the D-sub connectors to the back.
42C-03: Connected the 3-pin Micro-Fit Molex connector from the harness to the SV-BAT-320 Backup Battery.
58-06: Installed the SV-AP Knob Panel Modules and connected the D-sub connectors.
53-04: Re-installed the SV-ADSB-470 Receiver and connected the 9-pin D-sub and antenna cable to the back of the unit.
Secured the remaining loose wires with zip ties and lacing tape. Sprayed DeOxit Gold to the all the terminals that were connected.
29-06: Connected a USB cable to the back of the SV-D1000T and the other end placed inside the Map Box. Riveted the door hinge holes at the bottom of the Map Box. Clecoed the Map Box to the F-1202U Right Instrument Panel.
