My RV-12 Build Log
RV-12
SB 14-11-033
Wing skin/spar flange rivet wear SB
Drilled out the rivets from the bottom inboard of each wing. Clecoed the Doublers and match-drilled #30 holes. Final-drilled #22 the eight holes (each wing) per the plans. Used a thin steel plate to protect the spar caps from the drill bits.
Rivets drilled-out for doubler
Match-drilled holes in Left wing
Match-drilled holes in Rt Wing
RV-12 Home
2532
236
88
Finishing
288
838
189
372
Inspection
Modifications
189
Pre-Flight Checks
276
