Brief Description: Work on Wing Electrical Interconnector Update
I'm back to the Wing Electrical Interconnector Update. Inserted the wires with floating pins to the ES-00078 Floating Connector Male at the right side of the fuselage. Had to reposition some of the pins after finding out that I had inserted them in the wrong slots. Fabricated the WH-B740 Strobe Sync Wire and crimped floating pins to both ends. Connected the wire to both left and right floating connectors.
42D-22: Routed the audio power wires to the sides of the fuselage and tie wrapped them to the headset jacks per the plans. Started to work on the autopilot wires but there are inconsistencies between Sections 42D and 44A. I'll need to check with Van's to see what I'm supposed to do.
