My RV-12 Build Log
RV-12
Match-drilled Cowl Hinges
Match-drilled holes in the Upper Cowl Hinges. Deburred the holes and primed the hinges. Countersunk holes in the Upper Fwd Fuse Doubler that will be used to rivet the Cowl Hinges.
Cowl Hinges match-drilled
Bottom view of Doubler & Hinge
Countersunk holes inDoubler
RV-12 Home
2532
236
88
Finishing
288
838
189
372
Inspection
Modifications
189
Pre-Flight Checks
276
