My RV-12 Build Log
RV-12
Installed the Control Column
Bolted the WD-1210 Control Column to the 2 Control Column Mount Assemblies. It was challenging to install the required number of washers but the washer holders I had purchase before helped a lot. Torqued the bolts to specs and applied torque seal.
Close-up of Control Column (L)
Control Column bolted
RV-12 Home
2532
236
88
Finishing
288
838
189
372
Inspection
Modifications
189
Pre-Flight Checks
276
